Bugs? or catalogues needing tweaking
    • January 30, 2017 at 5:38 am #118684
      Grant Hughes
      First one is definitely a bug, I am finding that adding a background into the design sometimes renders and sometimes just renders white. Depending on how fusion is feeling. This can happen in single renders and batch, it also happens on the other machines in the building so I don’t think its my set up.
      Second one could be my setup: In elevations rendering in white fill, sometimes fusion only renders half an elevation. I find wire frame to messy (which is the only one gauranteed to work) for elevations and the higher level renders of elevations do the same.
      Third could just be a suggestion: I noticed some errors in the NDS Charles Rennie Mackintosh catalogue. The ones I have noted are that Fresco, Chic and Sheer are the wrong way round. Its always guess work to get the right one to render. I have also noticed that some of the door heights are misaligned to the catalogue. in particular the oven housings.
      Would someone be able to look into these?
    • January 30, 2017 at 8:06 am #118685
      Steven
      Hi Grant,
      Thanks for taking the time to post these. We have seen the first issue regarding backgrounds, you can expect this to be addressed in a future service pack/version of 2020 Fusion.
      As for the elevation and NDS CRM catalogue errors, I have asked a support agent to contact you to gather any additional details which you may have.
      Many thanks!
