CHOICE Cabinet Catalog
    • November 1, 2017 at 8:55 am #157794
      Chris Blackman
      I’m not sure where to direct the issues I’ve had with the Choice Cabinet Catalog.
      Wall cabinets using 1-Lite Mullion doors from Wall Accessories won’t show 1-Lite unless  you first select 4,6, or 8-Lite option and then choose 1-Lite. After 1-Lite appears you have to leave the other #-Lite option active or the 1-Lite is removed.
      Another issue is when using Mullion doors on a cabinet with more than 1 door the count of Mullions is set to 1, is there a way to set this so each cabinet does not have to be individually set to 2 if there are 2 doors?
      Wall cabinets with MEPW (matching end panel [left or right]) from Wall modifications while using a #-Lite door replaces the side panels with glass that match the doors. Not always what we would like to show.
      Sometimes when selecting the MEPW from Wall Modifications the list “jumps”(actually it seems to expand the list of options) and I end up selecting FEWL (finished end L) or whatever appears under my cursor where the MEPW option was when I clicked it.
      Things that seem to be missing from the catalog is something I need to bring up with the manufacturer, correct?
    • November 1, 2017 at 3:14 pm #157840
      Hey Chris,
      That very definitely sounds like a catalog issue.  I would definitely bring it to the attention of manufacturer.  Do the issues only occur in certain versions of 2020?  For example it worked fine in version 11.7 but in 11.8 you have the problem or is it a new catalog?
    • November 1, 2017 at 3:18 pm #157842
      Chris Blackman
      I have only used v11 from .3 forward.
    • November 1, 2017 at 3:24 pm #157843
      But has the catalog always done the same thing?  Or have you only noticed the behavior since updating the catalog?
    • November 1, 2017 at 3:33 pm #157845
      Chris Blackman
      For every version of the catalog from March until the most recent version. My Update Catalog button doesn’t work.
      I have tried running the UpdateCatalog MFC application but that just crashes now:
      Problem signature:
      Problem Event Name:    APPCRASH
      Application Name:    UpdateCatalog.exe
      Application Version:    11.8.1.69
      Application Timestamp:    59c94391
      Fault Module Name:    StackHash_adc6
      Fault Module Version:    6.1.7601.23915
      Fault Module Timestamp:    59b94a16
      Exception Code:    c0000374
      Exception Offset:    000ce85b
      OS Version:    6.1.7601.2.1.0.256.48
      Locale ID:    1033
      Additional Information 1:    adc6
      Additional Information 2:    adc639bcd5d92933dbf4d9ae9fa040c4
      Additional Information 3:    a093
      Additional Information 4:    a093d36e83ee744445cdd3c7b1430d5b
      Read our privacy statement online:
      https://go.microsoft.com/fwlink/?linkid=104288&clcid=0x0409
      If the online privacy statement is not available, please read our privacy statement offline:
      C:\Windows\system32\en-US\erofflps.txt
    • November 1, 2017 at 3:35 pm #157847
      Chris Blackman
      ok all of a sudden the Update Catalog MFC worked.
      I’ll check the new the Choice now.
    • November 3, 2017 at 3:41 pm #158417
      Chris Blackman
      still having the issue with the newest catalog as well.
    • November 7, 2017 at 11:14 am #158901
      Hey Chris,
      I think giving us a call at the 1-866-697-2020 support line is the way to go.  I’m not sure what you mean by the update catalog button and the issue is pretty odd.  It still feels like a catalog issue but maybe if you contact us we can set up a way to get the catalog from you so we can take a look at the files.
    • November 14, 2017 at 1:48 pm #160165
      Chris Blackman
      2020 Maintenance tool not working: SOLVED
      I couldn’t get any of the buttons in the maintenance tool to work before because I had copied the program to the desktop instead of putting a shortcut on the desktop.
      sigh
    • November 14, 2017 at 1:51 pm #160166
      I’m not laughing, honest I’m not….
    • November 14, 2017 at 6:14 pm #160261
      Lol. We’ve all done this or somethin similar.
