Hi Jeremy,
There is no way to change the default textures of the countertops you add. This is something you would need to do per individual designs.
A quick way to texture all your countertops at the same would be to use Global Attributes under the Items tab. From there you can select the catalog that the countertop came from and quickly change its texture!
