Create a Niche
    • July 21, 2019 at 9:49 am #243680
      Rose Roberts
      I have been using 2020 for 15+ years. However I’m just now trying to use it to the fullest capacity that its made for.  With that said I am working on a job right now that has a niche. Its not to the full ceiling so to make the walls the dimension of the niche wouldn’t be accurate.  I can’t seem to find the answer anywhere on here or online. I’m sure there is a way.
      Thank you!!
    • July 21, 2019 at 9:20 pm #243681
      I just create a double wall and use a wall cutout/passthru in the front wall. Example attached with a light in the niche. There might be an easier way but I haven’t found it (haven’t really looked).
      EDIT: The Facebook group has 2 queries on Niches:
      https://www.facebook.com/groups/2020PUG/search/?query=niche&epa=SEARCH_BOX
    • July 22, 2019 at 2:52 pm #243720
      Chris Setlock
      I use pass-through, as Mike said.  I don’t use a double wall, though.  I just place a surface over the niche opening, then edit in-out properties to move it to the back wall of the niche.
