December 3, 2014 at 8:03 am #19902
edwardstein
ParticipantIs it possible to scan a photo of a cabinet door not already in a 2020 library catalog and be able to import it in a catalog.? If so please describe how.
December 3, 2014 at 1:30 pm #19948
2020ParticipantHi,
Unfortunately this feature is not available in 2020 Design.
There is a feature called “Custom Material Wizard” the Wizard allows you to create and add your own textures from scanned or downloaded graphic images to your designs to be applied to Cabinets, Wall, Doors, Counter Top, Tiles and other items.
December 4, 2014 at 2:11 pm #20214
edwardstein
Participantwhere can this wizard be found in version 10.5?
December 4, 2014 at 3:23 pm #20218
2020ParticipantHere is how to.
Steps:
1. From any items attributes or Properties
2. Go to the option to change the texture
3. In the Textures dialog box, click the Custom Material button.
4. In the Custom Material dialog box, click the Wizard button.
5. In the Welcome screen of the Custom Material Wizard, click Next to open your graphic file.
6. In the Open dialog box, select the disk/folder where the file is located. Accepted graphic file formats are .jpg, .bmp, .tif, .png, .gif, .tga, and .lwi.
7. Follow the steps on the screen to complete the wizard. -
January 5, 2015 at 1:16 pm #21280
2020ParticipantDoor with Glass
Go to the Variables Tab
Find the Door Style (base, Tall or Wall) select the Style that your want
Then Right click on the variable and select Expression
The Add GLASS + before the Number (Glass + 12)Door with a horizontal center Rail, yes this is possible but you will need to download and install our custom catalogs (Design Plus
For step by steps please contact our support team at 1-866-697-2020
It will be their pleasure to assist you with this -
January 5, 2015 at 3:11 pm #21289
Haim
ParticipantThank you, but i think we misunderstood how can you select which glass door style. For example by wall cabinet in the design plus, you go to add-ons, then glass doors, and it gives you an option of 45 different glass doors. For Tall there is no add ons for glass, so i do i select one of the 45 for a Tall cabinet. Let me know.
Thanks -
January 5, 2015 at 3:15 pm #21290
Haim
ParticipantRegarding the Horizontal Center Rail. I loaded the Design Plus catalog and i am still unable to see any option for it. When i called support they said it was unavailable. Please let me know. I am really surprised from 2020, everyone uses a rail. I used it it Cabinet Vision. Is important to have it and to be able to adjust the rail to whatever height you need. i mentioned it a long time ago. Please get back to me.
January 27, 2015 at 10:23 am #22223
2020ParticipantHi Haim,
Sorry for the misunderstood
We didn’t add these add-ons for the tall cabinets. I will make a request for the next version.The only trick that I can give you is what I said before.
Add a Door style them Then Right click on the variable and select Expression
The Add GLASS + before the Number (Glass + 12)For step by steps please contact our support team at 1-866-697-2020
May 18, 2016 at 11:42 am #89008
carl standford
ParticipantHopefully this is something that they should work onto in the future. And for sure many will still use the idea than what is actually user today.
Regards.
Carl of https://caldwells.com/
