Deleted Notes
    • August 20, 2020 at 12:25 pm #294462
      Steven Brems
      How can I retain notes that I have placed on an elevation after I have closed the elevation?
    • August 21, 2020 at 11:46 am #294601
      Hi Steven,
      Any information you add to an existing elevation will only remain if you keep the elevation open. If you delete the elevation, then you are also deleting all the information you have added to it.
      What I would recommend doing instead of deleting the elevation is put your mouse on the bottom of the elevation line. This will change your mouse into a cursor with two arrowheads, one pointing up and the other pointing down. Once you see your mouse turn into this, you can left click and hold the mouse and then move the elevation up to make it smaller. – See attached image.
