I am new to 2020 Design and working on a Kitchen Project. For some reason I am not able to add elevations for some walls. I cannot seem to find or pick up the placement zones. I have gone into the properties of the walls and the placement zones all seem to be set up for inside. I am at a loss… Help!
The easiest way to select the placement zone will be using the Architecture tab.
If by accident the placement zone was removed through the properties of the wall you can simply copy\paste the design on a new FP, that will bring back the placement zone then just select the Architecture tab in order to easy select the placement zone.
