If I’m understanding what you are wanting correctly, then yes! There is a way! Double click on a blank space on your floor plan (or right click and select display settings) then go to “Warning Patterns” and turn off the offending color.
Personally I keep them turned off to do away with the hassle. If you decide to do this as well, after you uncheck the warning patterns you can click “Save As” at the bottom, and give it a name (I used “Danny Layout”), then click OK. Now go to File – Preferences – Display Tab Schemes. In the drop down of “All” you can select the saved style (so again, for me I would choose “Danny Layout.” Now all new designs going forward will save those preferences.
Note that any current or previous designs will need to be changed manually as it’s not retroactive.
Hope that helps!
