Hi Mike,
The codes generated for v9 and v11 are different. The versions use different code generators. However if you successfully apply a code in v9 the expiry date will also change for v11. The Key doesn’t care which version you run but the code applied needs to be applied with the license update tool appropriate to the generator used to create it.
I hope that makes sense
