June 27, 2018 at 5:21 am #192672
Yaprak Yalcinkaya
ParticipantHi,
I am struggling to get an external corner post for handleless doors in Universal Kitchen catalogue, at the moment I am creating two doors next to each other but obviously it is not giving me the same affect. Is there any other way to model this? Thank you
June 27, 2018 at 8:41 am #192674
Yaprak Yalcinkaya
ParticipantThank you Richie but I think that is a normal slab one, what I am looking for a J handle external corner post so it looks like the door is continuing, I have attached a picture of what I am looking for.
June 27, 2018 at 9:49 am #192687
RichardParticipantThe closest I can find at the moment is:
‘Insert’
‘Non Standard’
Catalogue = “TKComponents”
Drawing Group = “Base Cabinets”
Drawing Num. = “4204” – then press ‘TAB’ key.
Enter the sizes AND WHICH HAND you want it to draw, then click ‘OK’
This is an island end panel with two external corner posts and a base panel between. For base unit ends, just make it deeper and push it back into the wall a bit. I will keep looking and will post if I find something better, but this should get you through for now.
Internal corner post drawing number is 4161
Hope this helps.
June 27, 2018 at 10:06 am #192703
RichardParticipantFound it!
Same process, drawing number 10725.
I also found a small curved version, as some suppliers offer this as well, drawing number 10720 & 10721.
When you add them in to a design, save them individually as a grouped item with the supplier code as the saved name, so you don’t need to go through the process each time you want to add them to a design.
This should sort you out.
June 27, 2018 at 10:24 am #192716
Yaprak Yalcinkaya
ParticipantThank you very much!
July 29, 2018 at 4:08 am #196308
Chris Booth
ParticipantHi Try this – I modelled it , you just need to bring it in as a 3ds file . If the scale comes in abit weird just change the height to 715mm and it will correct all the other dims . Hope this helps – should end up as 715 x 70 x 70mm
