This is a small thing, but definitely a quality of life thing. Currently in Accessories it’s somewhat of a crap shoot where you will end up if you Tab to the next area. For Example:
If I’m modifying the Height of an item in attributes and the next data cell down is Depth it would make sense that if I press Tab I will be taken there. Instead I go to Up-down (which makes some sense, because it’s to the right), but next I go to Hinge (directly down, and a line below Depth), then somewhere I can’t figure out, then to the zoom portion, etc.
See attached for a visual picture.
Again, not a huge deal, but it’s common among virtually all software that Tab takes you to the adjacent field (or next in line)
