November 15, 2019 at 5:35 am #259748Yaprak YalcinkayaParticipant
I wondered if anyone got another solution to different floor levels, instead of creating box on top of the original floor? Also because it is a box, I can not use ‘floor coverings’ on this area either.
Another question is about wall coverings, will there be any update on these? Anytime I use wall coverings, I like to cover more than one side of the wall, for example if it is a pillar, or a nib, I like to cover it with different materials and different scales. At the moment, it only allows us to cover one side of the wall. Thanks!
November 18, 2019 at 10:51 am #259890Ollie Farrant2020 Expert
Hi Yaprak,
I can confirm that using a *box from Advanced Graphics is the way to create another floor.
To then apply a covering/material you would then need to use the surface cover tool. Please see below for an article on how to do this:
With regards to covering both sides of a wall, again you’d have to use a *box. We are currently looking into a way to achieve using a standard wall.
If you need any help with this please feel free to call us on 01233 533 533 or email us at fusionsupport@2020spaces.com
November 20, 2019 at 2:53 pm #259814Ryan JacksonModerator
Hi Yaprak,
To then apply a covering/material you would need to use the surface cover tool. Please see below for an article on how to do this:
With regards to covering both sides of a wall, again you’d have to use a *box. We are currently looking into a way to achieve this by using a standard wall.
Kind Regards
November 20, 2019 at 2:53 pm #259815Ryan JacksonModerator
Hi Yaprak,
Kind Regards
November 20, 2019 at 2:53 pm #259816Ollie Farrant2020 Expert
<p class=”MsoPlainText”>Hi Yaprak,</p>
<p class=”MsoPlainText”>I can confirm that using a *box from Advanced Graphics is the way to create another floor or split floor levels.</p>
<p class=”MsoPlainText”>To apply a covering/material to the *BOX you would then need to use the surface cover tool. Please see below for an article on how to do this:</p>
<p class=”MsoPlainText”>https://knowledge.2020spaces.com/articles/en_US/Designing_Your_Space/How-to-Add-and-Use-a-Custom-Image-as-a-Surface-Cover-on-a-Box-in-2020-Fusion/?q=surface+cover&l=en_US&c=Product%3AX2020_Fusion&fs=Search&pn=1</p>
<p class=”MsoPlainText”> With regards to covering both sides of a wall, currently you would need to use a *box instead of a wall, as using a * box will allow you to apply coverings\materials to all faces of the *box. We are currently looking into a way to achieve using a standard wall.</p>
<p class=”MsoPlainText”>If you need any help with this please feel free to call us on 01233 533 533 or email us at fusionsupport@2020spaces.com</p>
Thanks! -
November 20, 2019 at 2:53 pm #259817Larry Tamang2020 Moderator
<p class=”MsoNormal”>Hi Yaprak,</p>
<p class=”MsoNormal”></p>
<p class=”MsoNormal”>I can confirm that using a *box from Advanced Graphics is the way to create another floor.</p>
<p class=”MsoNormal”>To then apply a covering/material you would then need to use the surface cover tool. Please see below for an article on how to do this:</p>
<p class=”MsoNormal”>https://knowledge.2020spaces.com/articles/en_US/Designing_Your_Space/How-to-Add-and-Use-a-Custom-Image-as-a-Surface-Cover-on-a-Box-in-2020-Fusion/?q=surface+cover&l=en_US&c=Product%3AX2020_Fusion&fs=Search&pn=1</p>
<p class=”MsoNormal”>With regards to covering both sides of a wall, again you’d have to use a *box. We are currently looking into a way to achieve using a standard wall.</p>
<p class=”MsoNormal”>If you need any help with this please feel free to call us on 01233 533 533 or email us at fusionsupport@2020spaces.com</p>
Kind Regards,Larry Tamang
November 20, 2019 at 2:53 pm #259818Christopher WhiteParticipant
<p class=”MsoNormal”>Kind Regards</p> -
November 20, 2019 at 2:54 pm #259891Ryan JacksonModerator
Hi Yaprak,
Kind Regards
