How to add a window background.
    • March 10, 2016 at 12:18 pm #79529
      Lisa
      Hi.  I just loaded v10 and have spent a couple of days playing with it.  I can not find my window backgrounds.  I miss my trees.  Can someone help?  Thank you.
    • March 10, 2016 at 4:35 pm #79568
      Hi Lisa,
      Go to openings and obstacles. Select windows and then select scenery and scenery.  Then view the scenery, select the one you want and draw it outside the wall behind the window.  Then you will see the scene you selected through the window.
    • March 24, 2016 at 7:32 pm #81103
      Brenda Neufeld
      I’m working in V11, and trying to create an outdoor scene of Spring trees & grass; went through all the steps as stated above (thank you!), but my changes aren’t being saved and it keeps reverting to Basic color-25. After selecting my scene, I hit apply & ok, and went through this several times, even quit out and tried again. Is there a glitch? tx:)
    • April 7, 2016 at 10:04 am #84330
      Hi Brenda,
      It might be that, once you place the scenery the openings and obstacles box comes back on the screen.  If you you click on the view button in the openings and obstacles wizard again after you have placed a scene it thinks you want to place another one and defaults back to the basic colour 25 (white).
      Place a scene, close the openings and obstacles wizard and check in a perspective to see if the scene you selected shows in the rendering.  If you are still getting a white background give the 1-866-697-2020 support line a call because that is not normal behavior for the software.
