What do you mean when you say ‘reflect’ the panel – do you mean rotate from vertical to horizontal?
If you mean like the attached picture, I took a 720mm high, 18mm thick wall end panel and changed it to 30mm high and 700mm thick and then just changed the up/down of each panel as I copied and pasted it.
