November 10, 2017 at 3:52 pm #159921
Kerry FullingtonParticipantIs there a way to lock window and door positions in walls?
I inadvertently moved a window (that I had used to center a sink) by dragging it in a job and that could have caused a lot of grief had I not noticed it.
November 10, 2017 at 3:58 pm #159922
Santiago Morales2020 ExpertHello Kerry,
There is no way currently to lock the position of windows and doors. I have taken note of your suggestion to implement such behavior in an upcoming release.
Santiago
March 10, 2018 at 2:06 pm #175999
Rachel Borengasser
ParticipantSantiago,
This would be a much appreciated update!
Thanks, Rachel
March 12, 2018 at 8:30 am #176003
Santiago Morales2020 ExpertHello Rachel,
I also agree.
Currently a window can be moved out from a wall. Do you wish to lock a window from being pulled out from a wall or rather lock it altogether in position?
Santiago
March 12, 2018 at 8:03 pm #176089
Mike LangensiepenPilot ProHi Santigo,
I think she means that once we have created the architectural plan, that we would like to be able to lock all architectural items in place so as not to allow inadvertent movement/resizing.
We’ve had a few occasions where a designer has accidentally moved a window or resized a wall with resultant issues. Rachel, am I correct?
Cheers
Mike
March 14, 2018 at 8:41 am #176267
Rachel Borengasser
ParticipantSantiago, both locking the availability to move a window out from a wall AND locking it in position altogether would be great. Locking it in position altogether taking precedence.
Mike, you are correct, it would be awesome to have this functionality available on all architectural elements. AND I would venture to say ALL elements.
Thanks yall, Rachel
March 19, 2018 at 11:57 am #177007
Santiago Morales2020 ExpertThank you Rachel for the Feedback. It is noted.
Santiago
