March 22, 2020 at 8:48 am #274893
Perico Palotes
ParticipantHi.
I just installed 2020 Fusion 7 Trial in Windows 10. The first time it run it spend quite some time downloading catalogs and installing them. I did not get any error when it finished. Then the application restarted and I’m greeted with an error message saying “No catalogues have been installed”. After that I get straight into the Manage catalogues dialog which indeed is totally empty. If I click check for updates button I see a dialog saying Connecting to updates server https://foms.fusion.2020.net/catpatcher15/ and another error message saying: “Uninstalled updates exist. Please run Fusion design program to install these before checking for updates again.”
Running again Fusion results in the same errors.
In the logs I see also this errors:
PCSAutoCrash_OnLoadThe remote server returned an error: (404) Not Found.
[CffInstallUpdateManagerBase::InstallAvailableUpdates()] ERROR : MessageToObject failed.
[CfnFOMSMessageFileCreator::AddClientSystemInformation()] ERROR : Failed to set the system info.
No files installed in Catlib.ini file.;0
Any suggestion how to make Fusion work?
Thank you.
March 23, 2020 at 4:49 am #274894
Ryan Jackson
ModeratorHi Perico,
We will need to connect to your machine and have a look at this.
Please either email fusionsupport@2020spaces.com or call 01233 635 533.
Kind Regards
