Putting cabinets horizontally
    • October 24, 2018 at 7:37 pm #209983
      esat ISIK
      Hello,
      I want to put top cabinets horizontally.
      How can I do that?
      Instead of using small squares we wanted to put 30 h 15 wide cabinets horizontally so we can get the same 15H with 30 width with just 1 door.
    • October 25, 2018 at 10:18 am #210043
      Good Morning Esat,
      Unfortunately 2020 does not rotate items in that plane.  You can spin them around but you cannot flip them  on their sides.  You would need to find a catalog with cabinets set up that way in order to place them on the floorplan.
    • October 25, 2018 at 11:13 am #210047
      Mike Cook
      If you change the width and height in the attributes general tab it should give you the look you want.
    • November 21, 2018 at 10:22 pm #217333
      Vince Ruan
      Using the Sample F catalog, you can take a w3015 then change the door qty to 1 and change the pull position to center bottom horizontal to get the look of a horizontal flip up cabinet.
