I have only been working with 2020 for about a year and a half, maybe everyone else knows this but I did not. Trying to set a SB36 in a corner on an angel and lining it up with the corners of the cabinets on each side is hard to do, so I did some math. Using a construction master calculator, take the length of the sink cabinet and enter that under diagonal, enter 45 under pitch, select either rise or run a dimension will appear, add 24″(the depth of your side cabinet). Don’t set the SB yet. Say you want a B36D3 on the right side, set it on the wall you want it all the way to the corner, use your placement tool to move it, in this case 49 7/16″, repeat for the other side, Drag your SB36 in they will align and snap together. if you are using angled corners, your diagonal dimension will be to the inside of the corners after applied to the SB. I hope this was help full. if anyone knows a simpler way, please post it, I am still learning and need the help!
