August 6, 2016 at 3:00 pm #97487
Chris SetlockParticipantOK. I’m pulling my hair out today.
I need to send my kitchen plans to the cabinetmaker for so he can price the job for me. Normally, I use cutePDF to convert the floorplan and elevation to pdf (why doesnt 2020 do this internally, btw?). Then I’ll print a separate cabinet list.
No matter what I do, the elevations are small, and skewed to the left edge of the page. I know to resize them on my work area before attempting to print. I’ve done this repeatedly. I’ve also copied and pasted the design into a new file, in case there was an invisible object off in the distance. No luck. I’ve toggled “fit to page”/”scale” a few times, to see if it will re-fit, but that hasn’t helped either.
I then opened another kitchen from a couple weeks ago, and that one does it, too. It had not done this previously.
This seems to have started when I rolled back to 11.4, due to the texture issues I was having with 11.5.
August 7, 2016 at 8:50 pm #97490
Mike LangensiepenPilot ProI”ve not had this issue at all and I’ve hopped back and forth between 11.4 and 11.5 a few times.
Try using PrimoPDF instead of CutePDF. If the problem still exists, I’d recommend doing the 2020 Registry Reset procedure.
August 8, 2016 at 9:50 am #97570
Neil WilsonParticipantHey Chris,
Another setting you could check is the Print Area. Make sure it is set to entire design and not display.
August 8, 2016 at 9:57 am #97571
Chris SetlockParticipantPerfect! That cleared it up. Thanks, Neil!
