Before the update last year, you could make box to create skirting tile , when you added the same finish as what was on the floor to the boxing the grout lines matched up. Since the update this no longer happens & spoils the effect. Skirting tile needs to be a feature. The inability to run skirting into door reveals unless you make shorter walls & use boxw to make the head is another area that needs looking at.
