Have you ever had the following issue happen to you? You double click the Giza icon to open the program, you see the welcome screen appear, but then it goes away and the program does not appear to be opened anywhere on your screen.
The program is opened at this point, but it is likely just minimized down on the task bar. Move your mouse cursor over the Giza icon on the bottom task bar and hold it there until a smaller window appears above it. Now take your mouse and right click on that window, and choose Maximize. The Giza program should now reappear on your screen.
To prevent this from happening in the future, right click on your Giza desktop shortcut and choose properties. Then in the properties dialog change the Run drop down setting from “Normal window” to “Maximized”. Click Apply and Ok. This will ensure that every time you open Giza, it will open maximized by default.
