November 11, 2015 at 1:10 pm #57420
Bob A.
2020 PartnerAt this point in time we are unable to support Design 11 as it broke a major piece of functionality in our catalogs that has to do with modifying descriptions and manuf code via add-ons. These are required to reflect the changes in the dimensions of the item when a dimensional modification is selected via add-on. This worked in 9, worked in 10 (except for 10.3.1.38) and works in 10.5.0.27 but will not work in any release off V11. I would very much like to see this resolved.
November 30, 2015 at 9:28 am #62744
Christina
ParticipantAnother great reason to upgrade the software, is for troubleshooting purposes. The support team will only be able to report bugs or issues with current versions, therefore if you are running an older version and run into a bug; chances are it has been reported and corrected in a newer version. This will make your call to support shorter, and more efficient.
November 30, 2015 at 12:08 pm #62774
Bob A.
2020 PartnerI don’t feel the need to comment on this further at this time. You all have recognized the problem and we’ve been told that the target date to fix it is Feb. 2016. I appreciate the support we get on the previous version knowing full well that no new development will be performed on V10. I’m thankful that most of the issues our users experience are known and we can employ known good workarounds in these instances.
