October 25, 2017 at 9:07 pm
#157373
Phantom Cabinet? Well it is nearly Halloween!
I’ve seen this twice before but each had different circumstances and required different ways of fixing it (although the second way would probably have worked for the first one as well:
1) Use the Item List and see if the cabinet shows up there – if it does then delete it.
2) In the second case, the phantom cabinet didn’t show up on the Item List. In this case I drew a box round the actual design as closely as possible to select the walls, cabinets etc. then copied and pasted into a new design. This got rid of it.
Hope either method works for you.
