December 1, 2017 at 7:44 am
#162693
Hey Chris!
Thanks for the note and happy you were able to join us.
Try this. Double click on a cabinet and when the window opens choose the Variables tab and then choose Textures on the left of the new screen. If you see texture thumbnails on the right then you should be able to modify with the particular catalog you are using.
I recommend that you change the Door Texture first. Often times if you change that variable first, the rest of the cabinet components will automatically update too. If not, change each individually.
John
