Hello Daniel,
Thank you for reaching out. To be frank, we have not of such request in the past. It does not mean however it should not be considered though.
Are you suggesting having a background image in the perspective pane only? Or should it also appear in the high quality rendered pane (when selecting the camera button).
A couple of questions for you. How large would you need the background image to be? Should it be tiled and to what extent? Should its dimensions be custom configured?
Please note 2020 Design offers the capability to set a scenery image. This is a 3D object which surface is configurable and can accept an image. Moreover, the user can import a picture to 2020 Design through the User Texture Library mechanism.
As for the rendering difference you are experiencing, we recommend working in smaller window pane to get faster results and tweak the lighting accordingly. Once you are happy with the lighting effect, you can increase the pane to your licking and relaunch the process.
Let us know if this helps.
Santiago
