Reply To: Wishlist – assorted
March 9, 2018 at 3:48 pm #175861
Santiago Morales
Hello Gentelmen,
Thank you for all these great comments!
For #1 Access to Multiple Hardware Pulls, we will look at the capability to add pulls from different hardware manufacturers, not only to the ones included in the Cabinet Manufacturer Catalog. This what we make reference to Cross Catalog access. The good news is that we are considering this capability in our architecture for our Cloud solution.  If I understand correctly, we would need to be able to select a pull type, change its dimensions and position.  Most likely you would need to change its texture as well.
For #2 Change the Finish on a 360 Panoramic Image.  This sounds like a cool feature.  Unfortunately I have a hard time wrapping my head around how we could change do this type of manipulation an jpeg image.  I know we can perform some post image processing on colors but it could have some adverse effect on the entire image (not only the cabinets). Currently the only way is to re-render.  Mike, do you have a link to the tool you are referring too?  I would like to look into it.  Another challenge is that in order to apply the proper finish, the tool needs to have access to your library (our 360 server does not).
For #3  Configurable Light Color.   I agree with you, this looks rather simple to implement.  We will definitely consider it.
Thanks again, Santiago
