Reply To: 2020 Design problems.. again
April 30, 2018 at 4:19 pm #184326
Hey Matthew,
I never enjoy recommending going backwards but I don’t believe the issue occurs in version 11.8.2.  If you are pressed by a deadline you could remove 11.9 and install 11.8.2.  The rendering engine is the same in both builds so you should be able to get the renderings you want to show your clients in 11.8 and then you can update to the build that they resolve the issue in once they resolve it. 🙂
