June 29, 2018 at 10:22 am
#192985
Hi Hjames,
There is no preference setting for the size of the rendering window. The default window size is stored somewhere in the Windows registry . If you have a floorplan and a render open, once you get the rendering window sized the way you want it, go to the file menu on the rendering and select exit to close it. Then go to the file menu for the floorplan and select exit to close the software. This should update the setting in the registry and when you reopen the software you should should have the same size window as you had when you closed out. If you don’t something is preventing the software from updating the registries.
