Hi Jessica,
For the reasons you mention, I wrote a backup and restore script that backs up and restores all the 2020 settings including display schemas. You can download the script here:
https://www.dropbox.com/s/zb7tjqgbotx5rp8/V112020SettingsSaver.cmd?dl=0
Save it to your desktop. When your 2020 settings are EXACTLY as you want them, double click on the script icon. Choose the backup option and then answer Y to the next 2 questions. The script will create a folder on your desktop called 2020RESCUE with all the settings in it.
Nest time you have to run a registry reset, to get all your settings back, run the script again and choose the Restore option then answer Y to the next 2 questions and all your settings should be back.
The script was written for Windows 8, 8.1 and 10 and 2020 Design V11 so if you are not running these then the script will probably not work.
As the script is free, I give no guarantees as to correct functioning – use at your own risk. That said, the 30+ designers I support use it without issues.
