September 8, 2018 at 12:41 pm
#202506
Another trick with the Pucks is that you can go to Attributes, Variables and switch the default “YES” to “NO” for 3d.
No means you do not want it to render in 3d. It will still emit light, and you’ll see it on the floorplan – but it won’t render.
Also – remember you can use Horizontal and Vertical in the Variables to point the puck anywhere – even dead level with itself – (just not up) – so if you want to throw light perfectly horizontally to catch the top crown or something – you can.
