Reply To: Running bond tiles
December 20, 2018 at 3:39 pm #221514
Clare White
If it is for a backsplash 20-20 has a macro under>Item>Surface that you draw a rectangle in a clockwise direction, to connect the surface you have to right click on the mouse and it connects as a rectangle. To change the tile to another tile material right click the surface then select the texture and use the tile you want.
If you don’t like the tile selection that 20/20 has go to internet http://www.3Dwarehouse
