Reply To: Use non-default appliances in a catalog
January 29, 2019 at 11:09 am #225478
Thanks again Mike,
That is a good option.  You can also grab a picture of the front of the microwave you want and import it as texture and then place a surface over the “ugly”.
Also, you can usually change the appliance in a cabinet through the attributes/add-ons of the cabinet itself.  Select the catalog you want to pull the appliance out of from the drop dawn and see if you can add it.  See the attached image.
Hope that helps.
