March 22, 2019 at 8:05 am
#230770
Hi Neil,
Thanks for your quick response. As far a replicating the problem, it doesn’t consistently happen. It occurs for the most part when a design is complete, remove one or two cabinets, run a report, and then click the Undo button. Sometimes it works and sometimes it doesn’t. Trying to Undo something will generally not work when you’ve taken the focus away from the actual layout between the Undo and Redo actions. I hope this helps in getting a resolution. We’ve not experienced this issue before so I was unaware of 2020 working on improvements for those two action buttons.
