Reply To: Curve Seating
March 28, 2019 at 3:38 am #231253
David Boon
Here is what you can do achieve with *sofa. The table acts as a template & by making the sofa about 650mm deep 875mm high & 100mm long you get the ends & middle in place at the lengths you require for your particular sceheme  & you rotate freehand or move by 2/3/5 degrees the item. Attach the cursor to the the last segment , duplicate the segment & keep moving it into place
