March 29, 2019 at 10:16 am #231517
Hi Stacey,
In the lower right on your screen in an icon that looks like a little square grid with diagonal lines through it.  When you hover over it, you’ll see it’s acalled Ortho.  When it’s turned on, it snaps your walls to 45deg angles.  Turn it off.
When you drop your wall, you’ll be able to swing it freely, or you can take your hand off the mouse and use your number pad to specify the angle.  The numbers appear in the upper left.
Hope that helps!
