March 1, 2015 at 11:38 pm
#24037
I have had two issues. If you are doing a rending of a perspective and you hit the cancel button it will crash and you will have to restart.
Also designing using the current Dura Supreme Catalogs that work well on 10.6 if you do a height modification on Wall Cabinets it will let you modify and select the correct height but it does not change the graphic to the correct height on the elevation.
