Reply To: Elements not appearing in elevations?
June 25, 2020 at 11:49 am #287428
Customer Success
Hi Faigy,
Thank you for bringing this to my attention, I have been testing this out and it does appear to be a bug.
What the issue is, is that if you are using a single sided wall and add a door or window but place it to open on the outside of the wall, it will not appear in the elevation. IF you place the door or window to open on the interior of the wall, then it will appear in the elevation.
A workaround for this issue would be to create a double sided wall wherever you need doors and windows. Having a double sided wall will show the door and window regardless which direction they are placed. See the attached image as reference.
