Reply To: Lighting in V12.1.10.100 Very Dark?
July 10, 2020 at 4:20 pm #289148
Hi Kirstyn,
I haven’t heard any feedback about the program being darker than the previous versions. In our testing, we haven’t found this to be the case.
What I would suggest (because I don’t have the Underground catalog) is to use the lighting from within our own catalog. You can use lighting from the ROOM_FUR catalog. Double click on “lighting fixtures” and then you can select “recessed” and then “SPOT.RECESSED”. With these lights, you can intensify them via the Attributes>Variables tab.
Of course, you can always give our support department a call to make sure that the program is working as intended!
