Reply To: Item List Configuration
July 10, 2020 at 4:36 pm #289149
Hi Mark,
Sorry about that, I misunderstood. So i did a little testing with a few units and have found that it doesn’t matter which item was on the floor plan first.
If you have 4 walls (square) The item list will begin with the bottom right corner of the square and move in a clockwise motion.
If you have an L (Left wall with a top wall) It will start with the first unit on the top wall and then continue in a clockwise motion.
If you have a 3 wall design (Top wall, Right wall, Bottom wall) It will start with the first unit in the upper left hand corner and continue clockwise.
Hope this helps!
