Hi Laura,
Normally when this happens, it is because there were items that were placed very far away from the rest of the drawing. In my experience, this could be a unit of some sort, a line, or it could have even been an add-on that was place way off of an item.
You can go to the item list of your design and select everything in there and then go back to your floor plan. When you have everything selected, you should be able to see the ‘blue dots’ that surround your items. This will help locate the drawing on the floorplan but after that you would need to identify which item is far away from the drawing. You can also contact our support department so a tech can connect in and assist with this. You can reach us by calling 1.866.697.2020.
