Reply To: WishList
June 16, 2022 at 6:31 pm #371380
Erik Tornquist
Woah, You hit the nail on the head!
-The window attributes problems as mentioned have been a pet peeve.
-You should be able to select all measurements by pressing “shift” or “CTRL” then delete them that way. I think you used to be able to move all selected measurements at one point too but that doesn’t seem to work anymore.
-Didn’t realize the disappearing placement wheel was something others found annoying; thought I was the only one. I’d also like to add, in Coordinates (Placement), adding height coordinates to be able to input how high an item is to be from the ceiling or floor
-Personally, the only time my  program crashes is when I copy/paste an item already taken from Cloud (crashes almost 100% of the time) or changing attributes from any Cloud item (happens occasionally).
