Hi Everyone, Is there a way to disable the corrective process that Fusion 8 does at the end of the rendering to smooth out the textures. It’s making a lot of my renderings look a bit smudged if that makes sense. I can post a before and after from the two different versions if you want to see an example. Thank you<!– [if gte mso 10]>
<style>
/* Style Definitions */<br />
table.MsoNormalTable<br />
{mso-style-name:”Table Normal”;<br />
mso-tstyle-rowband-size:0;<br />
mso-tstyle-colband-size:0;<br />
mso-style-noshow:yes;<br />
mso-style-priority:99;<br />
mso-style-parent:””;<br />
mso-padding-alt:0cm 5.4pt 0cm 5.4pt;<br />
mso-para-margin:0cm;<br />
mso-pagination:widow-orphan;<br />
font-size:10.0pt;<br />
font-family:”Times New Roman”,serif;}<br />
</style><![endif]–>
<!– [if gte mso 9]><xml>
<w:WordDocument>
<w:View>Normal</w:View>
<w:Zoom>0</w:Zoom>
<w:TrackMoves/>
<w:TrackFormatting/>
<w:PunctuationKerning/>
<w:ValidateAgainstSchemas/>
<w:SaveIfXMLInvalid>false</w:SaveIfXMLInvalid>
<w:IgnoreMixedContent>false</w:IgnoreMixedContent>
<w:AlwaysShowPlaceholderText>false</w:AlwaysShowPlaceholderText>
<w:DoNotPromoteQF/>
<w:LidThemeOther>EN-US</w:LidThemeOther>
<w:LidThemeAsian>X-NONE</w:LidThemeAsian>
<w:LidThemeComplexScript>X-NONE</w:LidThemeComplexScript>
<w:Compatibility>
<w:BreakWrappedTables/>
<w:SnapToGridInCell/>
<w:WrapTextWithPunct/>
<w:UseAsianBreakRules/>
<w:DontGrowAutofit/>
<w:SplitPgBreakAndParaMark/>
<w:EnableOpenTypeKerning/>
<w:DontFlipMirrorIndents/>
<w:OverrideTableStyleHps/>
</w:Compatibility>
<w:BrowserLevel>MicrosoftInternetExplorer4</w:BrowserLevel>
<m:mathPr>
<m:mathFont m:val=”Cambria Math”/>
<m:brkBin m:val=”before”/>
<m:brkBinSub m:val=”--“/>
<m:smallFrac m:val=”off”/>
<m:dispDef/>
<m:lMargin m:val=”0″/>
<m:rMargin m:val=”0″/>
<m:defJc m:val=”centerGroup”/>
<m:wrapIndent m:val=”1440″/>
<m:intLim m:val=”subSup”/>
<m:naryLim m:val=”undOvr”/>
</m:mathPr></w:WordDocument>
</xml><![endif]–>
