July 11, 2022 at 9:45 am
#372902
Another Wish: To change default font settings (style, color, size, etc…)
Also, trying to copy and paste a note in the elevation, requires you to move it around on the floor plan, which doesn’t show up anywhere in the elevation. Heck, doesn’t even seem to show up on the floor plan; not that i can see at least. I understand that it’s coded in a way that whatever is copied in an elevation has to be pasted in the floor plan but if there was any way that copy/pasting Annotations in an elevation, stays in the elevation… that would be so helpful.
So when I want to write notes with a similar font setting, I have to go into each note and adjust it manually. That clearly takes a bit of time when having a lot of notations.
Just a thought.
