Reply To: Moldings Disappearing in Rendering View
September 13, 2022 at 12:11 pm #375260
Hi Laura,
Normally toe kicks should still be present in the perspective view regardless if there is a placement zone or not. -See attached image below. As you can see, the toe kick still appears in the perspective even when outside of the placement zone.
The only time the placement size will matter is when trying to view the elevation of a particular wall. The elevation will only show items that sit within its placement zone. -See attached image.
If the issue you are experiencing is with the perspective view, I would suggest to contact our support department so an agent can connect to the system and take a closer look at what is happening. You can reach us by calling 1.866.697.2020.
