October 7, 2022 at 11:17 am
#376106
Hi Matthew,
The only way to use Design on a Mac would be by installing Bootcamp which will split your computer in two giving you access to a Windows side. Once you do that, you can download and install Design on the windows side to get it set up. Just make sure that the system has the requirements needed to run Design as intended.
HERE are our system recommendations.
