July 19, 2015 at 9:23 pm
#38976
Right click on a blank area in the Floor Plan or the Elevation. Go to Display Setings and click on the Dimensions tab.
Make a note of the name of the Schema.
Now expand the categories (click on the ‘+’ symbol) until you drill down to the category you want. Untick boxes to switch off unnecessary dimensions. When you are happy, save the settings to the original file name that you made a note of above (click Save As and scroll through till you see the file name then click and answer ‘Yes’ to the overwrite question that will come up).
Same method applies to elevations and floor plans. You can also switch item display on and off and alter other settings such as the area snap, grid spacing and so on.
