Hi Nader,
The only curved wall option you can use in Design are the curved walls you’ve attached above. You can find the radius of the curved wall by going to Annotations and using the Radius tool. Once you acquire the radius of your wall, then you can use math to find the length of the wall.
For instance, if I add a Concave Wall R to my design, I can use the Radius tool to find its radius. – See Attached File. Once you find the radius, then you can multiply it by 2 to get the diameter. Once you have the diameter, you can multiply it by pi (3.14) to obtain the length of the wall (if it was a full circle). Then you can divide the full length by 4 (for the quarter wall we have) to get your wall length. In this case, we would do 32 x 2 = 64 .. 64 x 3.14 = 200.96 .. 200.96 divided by 4 = 50.24. So our Concave Wall R, by default, has a length of 50.24 inches.
Hope this helps out!
