May 16, 2023 at 11:20 am
#423630
Hi Rick,
You can manually add countertops to your design by going to the ROOM_TOP catalog. Select ‘Counter Tops’ – ‘Pre-Defined Top’ – and use the STRAIGHT TOP.
You can modify the countertop size by right clicking the top and using ‘Edit Shape’. You can change the counters Up/Down by going into its Attributes, and you can change the height (thickness) of the countertop by going into its Attributes > Variables. From Variables, you’ll also have the ability to change the texture of the countertop.
Here are two articles than can help with modifying your countertop.
How to Edit Countertops, Surfaces and Trims
How to extend a Countertop (add a line) in 2020 Design
