January 8, 2024 at 3:19 pm
#435825
Hello Melina,
Yes, that’s correct. Tech support logged in and the technician told me that they frequently run into issues where during routine updates and so forth, 2020 stops using the GPU memory. Normally they can fix it for you, but on my system for whatever reason 2020 simply wouldn’t do it. My system is good enough that it still works more or less fine, but it is frustrating. It also means that if I’m doing high quality renderings, I can’t really use my system for much while they render, which is annoying.
