March 7, 2024 at 3:29 pm
#437364
Update:
I was able to replicate the error on my boss’s computer as well, and he’s running an older version of 2020 Design.
It happens even when no cabinet manufacturer catalog is used- If you draw a room using only 2020’s wall tool and standard doors and windows, and change the top alignment, everything shifts to one side. The amount & direction it shifts will be the same every time you do it in a given design, but differs between designs.
It only does it when adjusting the top alignment for the entire wall group; Setting the alignment for individual walls does not cause it to happen.
I was able to call tech support while it was happening, they were able to log into my system and watch it happen, and took a report.
